need wiring harness
need wiring harness
i am new to the honda scene i just bought a 92 civic si hatch with a gsr swap. the guy just took the whole harness from the integra and put it on the hatch. the wiring for the engine is great but all the wires for the lights SUCK the driver side turn signal comes on but doesnt flash when you have the turn signal on but the passenger does. when you turn on the headlights the passenger headlight comes on but the driver side doesnt. turn on the high beams it turns on the low beam for the driver side and passenger is still on low. i tried to rewire but the wires r so hacked up its hard to find whats what. so i just need a si wire harness with the light wire and i will just add what it needs to hook up to the gsr by the way the gsr is a 94 dont know if that helps.
Seagull Management
Re: need wiring harness
Wait, you mean he used all of the GS-R harnesses?! Why?! The GS-R engine harness plugs right into the civic chassis harness at the shock tower plugs, leaving you with only the IAB and Knock sensor wiring.
yes but integra has 2 headlights one low and one for the high and civics just have one and he tired to put them together and this i what i got jacked up lights everything on the motor is fine just the light tow up
Seagull Management
Yeah, thats what i'm getting at. The part of the harness that goes to the headlights isn't part of the engine harness at all, its actually part of the underdash harness. They aren't fun to replace either, you pretty much have to strip the front of the car right down to the bare floor. And if he used the integra underdash harness he probably used the rest of the integra interior harnesses in the car. No one is going to give you and Si harness btw, they aren't cheap or easy to find. Next closest thing would be an EX underdash harness, followed by a '92 CX underdash harness (the year is important)
Ritchie
07-29-2006 02:34 PM
gezer
08-28-2004 11:33 PM
