Need wiring diagram for GSR cluster into 92-95 Civic
Doing this and I'd appreciate it if someone could hook me up with the diagram. Either here or by email. redlinedvtec@hotmail.com. TIA
Ben
Ben
Re: Need wiring diagram for GSR cluster into 92-95 Civic (RedlinedVTEC)
i need it also. . .so please post or email me at freaknrican42@aol.com
Re: Need wiring diagram for GSR cluster into 92-95 Civic (B_zurC)
Re: Need wiring diagram for GSR cluster into 92-95 Civic (JV)
teg's blue left side plug (13 pins)
1.blu-tach signal
2.grn/org-check engine indicator
3.yel/red-oil pressure switch
4.-
5.wht/blu-charge indicator
6.-
7.yel/grn-coolant temp
8.blk-ground
9.red/blu-cruise (if you have cruise)
10.yel-hot
11.-
12.pink-maintenance (not used)
13.-
teg's right side blue plug (16 pins)
1.grn/red-e.brake signal
2.red/grn-high beam
3.grn/yel-right turn
4.grn/blu-left turn
5.-
6.blk/yel-power
7.red/blk-power
8.red-power
9.blu/red-abs (not used)
10.grn-trunk switch
11.org-vehicle speed sensor
12.-
13.blu/wht-low fuel (not used)
14.yel/wht-fuel gauge
15.lt grn/red-door switch (not used)
16.red/blu-seat belt
civic's left side grey plug (12 pins)
1.yel/wht-fuel gauge
2.yel/blu-vehicle speed sensor
4.grn/blu-left turn
5.wht/blu-charge
6.yel/red-oil pressure switch
7.-
8.blu-tach signal
9.-
10.blk/yel-power
11.red/blk-power
12.red-power
civic's right side grey plug (10 pins)
1.red/grn-high beam indicator
2.grn/red-e brake signal
3.-
4.-
5.grn/org-check engine indicator
6.blk-ground
8.yel-hot
9.grn-trunk switch
10.blu/wht-seat belt
there you go
1.blu-tach signal
4.-
6.-
8.blk-ground
10.yel-hot
11.-
13.-
2.red/grn-high beam
4.grn/blu-left turn
5.-
6.blk/yel-power
7.red/blk-power
8.red-power
10.grn-trunk switch
12.-
4.grn/blu-left turn
5.wht/blu-charge
7.-
8.blu-tach signal
9.-
10.blk/yel-power
11.red/blk-power
12.red-power
3.-
4.-
6.blk-ground
8.yel-hot
9.grn-trunk switch
there you go
jdmcivicferio
18
08-20-2004 07:26 AM
eg6ajk
13
02-02-2002 06:09 PM
