Need Vtec help!!
Need Vtec help!!
i have a 2000 civic si with the b16a2 and its throwing a code 22. Which i found out is the vtec oil pressure switch i checked it and its plugged in. my vtec works but sorta cuts on and off at higher rpm's its done it twice in 4th at 7800 and once in third at 7500 it sounds as if my vtec cuts on and off could it be my vtec oil pressure switch and if so where can i find and price one.
1 Post
Re: Need Vtec help!! (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">change your oil</TD></TR></TABLE>
what he says, then go from there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">it dosent mean the switch is bad, it means there is low pressure.
Or if you're lazy and we-todd-did just add a quart of oil and run it to see if its fixed.
Re: Need Vtec help!! (EKology)
i had that problem with my h22. i couldn't figure it out, so i just changed mine with a friends( he doesn't know it yet) but he is selling the car so it didn't matter. is your oil pan bent dented at all?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKology »</TD></TR><TR><TD CLASS="quote">
Or if you're lazy and we-todd-did just add a quart of oil and run it to see if its fixed.</TD></TR></TABLE>
too much oil = BAD
too much oil = BAD
