!!! Need v-afv/turbo help imediatly!!!
Need v-afc/turbo/cel help
problem fixed, thanks for the help
Modified by trecool44 at 4:56 PM 10/2/2005
Modified by trecool44 at 6:19 PM 10/4/2005
Re: !!! Need v-afv/turbo help imediatly!!! (trecool44)
you should check all your wiring and since you havent boosted yet how did you set up the hack? how much fuel did you take out completely over the entire rpm band? ohh and buy a wideband
Pooping on children
when i setup the idle with afc i did 450/240 this gives you -46% thats a number to start your idle setting at. although my idle percentage ended up at -31%basically i let the car run and gave it fuel untill it stopped runiing like crap. Oh are are you using a resistor box with you dsm injectors? also how much vacuum is it reading? if its like -.04 its completely normal
freeplay
10-20-2002 09:05 AM
