Need Suggestions on suspension problem
My car started to give out some weird noise from underneath, sounds like metal rubbing each other, checked, not low-ball joint, not sway bar endlink, not the coilovers, not sure about sway bar bushing or suspension bushings itself.
Whenever jack-up the car, the noise is gone, but it start to give out metal rubbing sound again after put it back on road, no matter parking, turning, start from light, braking, its driving me nuts.
Anyone here has the same problem that can give me some suggestions what the problem is? BTW, my car is a EG hatch. TIA
BTW, I posted in Tech Forum but not much ppl viewed it so I am hoping to have some luck here.
Re: Need Suggestions on suspension problem (EG6_SiRII)
You checked everything? heat shield on cat, heat shields on brakes? Checked your brake pads? Possibly the wear indicator digging into the rotor?
