need someone to confirm all this materials is enough to install R-Sway on 95ex coupe
here is the list of stuffs i will need...
I GOT ONE QUESTION: What about the LCA of my 95ex coupe, can it be reuse or i have to drill a hole in both R-LCA.
Here are the Acura parts that will be need:
1.) 52300-ST7-Z01 rear swaybar ($58.22)
2.) 52315-ST7-Z01 swaybar bushing ($3.27) (2 needed)
3.) 52308-SS0-000 bushing bracket ($5.14) (2 needed)
4.) 52316-ST7-Z00 endlink bushing ($1.46) (2 needed)
5.) 52312-ST7-Z00 endlink bushing collar ($4.16) (4 needed) – this part can be reused from the stock swaybar
6.) 90175-ST7-Z00 bolt (8x35) ($2.06) (2 needed)
7.) 94050-08080 flange nut (8mm) ($0.10) (2 needed)
Here are the miscellaneous parts that will be need:
1.) 1/8" thick x 1.0" wide x 3.5'' long piece of plated steel (2 required). *** INCLUDED IN MOUNTING KIT ***
2.) 1/2" (H) x 5/8" (OD) x 5/16" (ID) aluminum or steel spacer (2 required). *** INCLUDED IN MOUNTING KIT ***
3.) washers (inside diameter(ID) = 3/8") (outside diameter(OD) = 1") (2 required). *** INCLUDED IN MOUNTING KIT ***
Re: need someone to confirm all this materials is enough to install R-Sway on 95ex coupe (GsR-Freak)
Yeah, that looks about right. But you might want to invest in a subframe reinforcement kit.
Re: need someone to confirm all this materials is enough to install R-Sway on 95ex coupe (SOHC4life
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">Yeah, that looks about right. But you might want to invest in a subframe reinforcement kit. </TD></TR></TABLE>
Not needed. Subframe cracking is known more in 96 and up civics for some weird reason. Not for our year. But if you want to be better safe then sorry then more power to you
oh sorry i didn't state rear or front. IT for the rear.....but the question is that...DO I NEED A NEW lca for my rear?
if you car already has a sway bar (from factory) then no, you do not need new LCA's. however, if you dont have a stock rear car ( like me) then you need new LCA's that have threaded holes for mounting the endlinks.
which model of LCAs from integra cani use? GSR TYpe R and what else
dgdarien
02-03-2003 12:23 PM
