Need some info on HX wheels------>
I've kinda been drawn to the attention of the wheels that come on the hx. look pretty good to me. but do they only come in 14? and how much do they weight. im thinking for getting some and poweder coat them black. thanx let me know.
Re: Need some info on HX wheels------> (sirminder)
check this link.. no pic but the rims u asked for..
http://www.wheelspecs.com/specs/wheelmodels/174
damn I just checked wheel weights and the ITR 4 bolt pre 98 spec only weigh 12.3lbs for a 15x6 rim.. pretty light for some stock 15s
[Modified by IM ALL BOB, 11:40 PM 8/18/2002]
New User
Re: Need some info on HX wheels------> (CovertFI)
the ones off of a 6 gen civic will not fit an ex. an hx comes with the same small calapers from a dx. the ex has larger calipers. trust me i know this
Re: Need some info on HX wheels------> (Unjockable)
I'm pretty sure you're right. My friend tried putting them on his integra but it didn't work.
well i guess im in luck, cuz i have a 95 dx. i just need something lighter than the wheels i got but better than stock. i just realized i should of bought some lighter wheels doh!! but anyway, they are some motegis mr8 thinking of selling them, who knows
HX rims =
A little bit of clarification though... the HX wheels WILL fit on a 5th gen EX or Si, IF you feel like either A) shaving some of the caliper off... I can't exactly explain the location, but if you have HX wheels and want to mate them to an EX or Si, you will see what I mean when you try to put them on. the other option is B) just get a spacer to add a little more offset. I chose to go the caliper shaving route, just because I have an air-grinder and I'm impatient and didn't want to wait for someone to ship me spacers.
BTW, this is on the fronts on an EX. The wheels fit fine over the rear drums, not sure about rear discs on an Si...
Also, here is a pic of my 95 EX coupe with gunmetal HX's on it.
(more pics here: http://roots.zapto.org/~mjohnston/081702 ... yeah, the camber is horrible, I'm working on that... )
[Modified by matt-eg, 10:25 PM 8/19/2002]
[Modified by matt-eg, 10:28 PM 8/19/2002]
The spacers should be easy to find... it's just an aluminum or steel round plate with 4x100mm lug pattern holes drilled in it. Ask at an auto parts store, or maybe at les schwabb or something.
If it were me, I'd get the same spacers all around just so your front wheels don't stick out more than the rears...
the hx'x weigh 14 lbs each and i got them on my 96 civic but i had to use wheel spacers on front so they would clear the calipers.
Re: Need some info on HX wheels------> (EGkwazhimoto)
VX wheels are 13", HX wheels are 14". The dish part in the center of the wheel looks a little different too.
What's the story behind that car? Looks rough...
speaking of HX's, I just stripped the paint of of mines and it looks pretty nice without painting it. Machined HX's look hard as hell IMO.
[Modified by B_Cruz, 3:51 PM 8/19/2002]
Re: Need some info on HX wheels------> (B_Cruz)
i think i might pick up some of these for my car. are the lx calipers the same as the ex ones . also is there another place online that i can look for them other then ebay.
thanks in advance
thanks in advance
1 Post
