need some help in clarifying where these problems are coming from *92 civic hatch*
How yall doing, I recently purchased a 1992 honda civic si hatch had a blown motor and all in it, I replaced it with a jdm b20 from JEI and put in hasports mounts along with it
I stripped the back seats because the car had a upgraded fuel pump and I needed to replace it with a stock fuel pump and never got back around to putting the stock seats back in, put on a seibon cf duckbill and new jdm corner lights
Car is making some noises, from the sounds of it it seems like the back window is shaking at certain speeds and mph but I cant figure it out considering it only does it during when I drive
What are the common cracks and rattles that yall know of and how do you go about fixing them so this annoying **** doesnt happen everyday I drive the car??
I'm not Rick!
Re: need some help in clarifying where these problems are coming from *92 civic hatch
theres a billion problems honda has.
why did you take out the other fuel pump?
does it drive fine?..jus weird chassis noise?
tighten all the nuts and bolts everywhere in the back.
check the rubber seals around the windows. if you take out the carpet (temporarily) youl find alot of stuff
I took out to the other fuel pump because it had a upgraded aftermarket fuel pump in it
Did you get it from JEI in doraville Ga?
X2 on tightening all bolts and stuff
I'm not Rick!
yeah an upgraded fuel pump...why did you take that out and put a stock one in?
are you talkign about a walboro 255lph, you can use that with the b20 stock
and grease some joints.
djordan1
09-15-2010 04:42 AM
vtikilla
13
05-08-2007 09:29 AM
92redhatch
12
08-09-2006 08:23 PM
SiB16A
50
04-12-2006 05:48 PM
