need pinout for p2e ecu
Technical Hero
Re: need pinout for p2e ecu
You didn't say what year the ecu was out of or what four wire 02 primary or secondary :
ECU DIAGRAM
http://technet.ff-squad.com/wiring.obd2a.htm
96-98 OBD2A
99-00 OBD2B
http://technet.ff-squad.com/wiring.obd2b.htm
ECU DIAGRAM
96-98 OBD2A
99-00 OBD2B
ECU DIAGRAM
96-98 OBD2A
99-00 OBD2B
ECU DIAGRAM
96-98 OBD2A
99-00 OBD2B
Then the OBD2A pinout is the one you need.
Why are you using an EX ECU on a DX/LX motor? It definitely isn't the ideal match. The biggest differences off the top of my head are the lack of vtec, and the fact that the Y7 uses 190CC(180?) injectors, whereas the Y8 (EX) uses 240CC (230?) injectors.
Technical Hero
Use the first diagram posted for OBD2A.
If you want to confirm match the ecu connector and make sure it is:
http://hondata.com/techecuid.html
Technical Hero
ive already learned what i need to know about my engine i just need the pinout for the 4 wire o2
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/97-civic-hx-d16y7-swap-iacv-p1509-o2-sensor-p0135-cel-codes-3120297/
bhive9024
05-09-2003 09:53 PM
