NEED OPINION ON MY NEW SETUP
It was supposed to be a B20 Vtec But ran into an awsome deal on a block so picked it up. I never done a B16 Head on a GSR Block so not too familiar with this. Can anyone tell me any improvements i need on this build before i start getting down and dirty?????? And How much power i can possibly get out of this setup???? THANX IN ADVANCED
AT HOT IMPORT NIGHTS HI
AT THE DYNO
I Sold my old hatch and bought this one wit a blown motor
This car get choke JDM parts
Interior shot of all the goodies......
OLD POWER PLANT, NEW POWERPLANT COMING SOON....STAY TUNED
HEAD
B16 p30 head
port flow
5 angle valve job
Bronze valve guides
skunk2 valve springs and retainers
skunk2 stage2 pro series turbo cams
skunk2 pro series cam gears
skunk2 cam seal
J's Racing valve cover
J's racing oil cap
EDELBROCK VICTORY X INTAKE MANIFOLD PORTED TO MATCH HEAD
Edelbrock 70mm TB
Hondata intake manifold gasket and THrottle Body gasket
MSD Spark Plug Wires
MSD Distributor external coil and cap
commetic head gasket
greddy timing belt
ARP head studs
ARP Turbo Manifold Bolts for head
BLOCK
96 B18c1 GSR Block
Benson sleeve 81mm stock bore, sleeved and built by Benson
CP Pistons 9:1 compression
Manley Rods
GSR Crank
Blueprinted and Balanced
BOOST
Full Race T4 Ram Manifold Wrapped with exhaust wrap
Garret GT40 V Band
3" Downpipe with full 3" exhaust wraped with exhaust wrap and 4" truck tip
Full Race intercooler 2 1/2" piping with couplings/clamps wrapped with exhaust wrap
Tial 44mm waste gate
Tial 50mm BOV
Apexi AVR Electronic boost controller/ timer
SX Intercooler
custom waste gate dump tube
3 Bar Map sensor
Golden Eagle Vacum Block
Tranny
GSR TRANNY with 97 CTR LSD
Exceedy Twin Disc with Built in Flywheel
ARP Flywheel Bolts
The Drive Shop stage 5 axles with hub
Transmission Blanket
SUSPENSION AND HANDLING
Type r Tein Flex suspension
Type R rear sway bar
Function7 rear LCA's
ASR Subframe
All Spoon Bushings
Spoon Twin disk calipers
spoon braided brake lines
Miracle X Bar
6 Pt Custom Cage
JIC front upper struct bar
spoon rear camber kit
L CON Racing Traction Bar
ENGINE MANAGEMENT/ COTPIT
AUTRONIC ENgine management
Omori, oil pressure/ Temperature guage
Omori Boost guage
Omori Temperature guage
Omori Volts guage
Odossey Battery
Spoon Vtec Controller
Oil System
ENDYNE Oil catch can
Greddy Oil Cooler
Endyne Racing oil pump
Moroso oil Pickup
Moroso 5.5 qt Oil pan
Cooling
Spoon 1.3 Radiator Cap
Fluydine half sixe radiator
Spoon Radiator Hoses
Spoon radiator cap
Type r water pump
J's Racing Front Air duct
FUEL
Paxton 1K cc Fuel Pump
RC 1K cc Injectors
AEBS Fuel Rail
SX FPR
All steel braided fuel lines
ACESSORIES
BYS Front CF LIP
BYS REAR DUCKBILL
Vision CF mirrors
Modified by B20_hatch at 11:25 AM 5/12/2008
Modified by B20_hatch at 11:33 AM 5/12/2008
Modified by B20_hatch at 11:58 AM 5/12/2008
Modified by B20_hatch at 12:14 PM 5/12/2008
Modified by B20_hatch at 12:15 PM 5/12/2008
AT THE DYNO
HEAD
B16 p30 head
port flow
5 angle valve job
Bronze valve guides
skunk2 cam seal
J's racing oil cap
Edelbrock 70mm TB
greddy timing belt
ARP head studs
BLOCK
96 B18c1 GSR Block
Manley Rods
GSR Crank
BOOST
Garret GT40 V Band
Tial 50mm BOV
SX Intercooler
3 Bar Map sensor
Tranny
ARP Flywheel Bolts
ASR Subframe
All Spoon Bushings
Miracle X Bar
6 Pt Custom Cage
Omori Boost guage
Omori Volts guage
Odossey Battery
Oil System
Greddy Oil Cooler
Moroso oil Pickup
Cooling
Spoon radiator cap
Type r water pump
FUEL
RC 1K cc Injectors
AEBS Fuel Rail
SX FPR
ACESSORIES
BYS Front CF LIP
BYS REAR DUCKBILL
Vision CF mirrors
Re: NEED OPINION ON MY NEW SETUP (B20_hatch)
lol sorry i got distracted before i got into any of your parts but my valve cover is the same color... looks sick. but from what i have heard the B16 and Type R heads are the best flowing heads so sounds like your setup is solid.
Justlearning95
09-20-2016 06:57 PM
