Need Little Help! 96 EX w/B16A swap
From what car do I get the upper radiator hose so it will fit the b16A. I also have 2 electrical plugs that there is nothing to plug them into. One was for crankshaft on the D16Y8 and the other was next to the vtec plug. Do you not use these two plugs on the B16A? Thanks!
Re: Need Little Help! 96 EX w/B16A swap (eargsm1)
It is a 97 motor. Thanks for the help. I thing one of the plugs was for the crankshaft on the old motor not sure what the other was for next to the vtec plug.
Iwould think 99-00 si hoses would work
One of the plugs is prbably for the vtec pressure switch, if your swap is JDM it most likely doesn't have one . the other plug i don't know.....good luck
Re: (egsleepercivic)
Thanks for the help! I got everything back together and Started Up first try. Runs great except the clutch is only catching about half. I bled the clutch and can't get it to work right. Either something isn't right or the clutch is going out in it. I can get the car to go with little gas but give it more and it revs high while picking up speed slowly like the clutch is half way out. Any suggestions? I was hoping to drive my car again. Don't want to wait any longer!!!!
namewasdallas
11
07-25-2011 09:59 AM
