need to know if there is such a thing as a p3p ecu?
ive got a ecu but cant figure out if its from a civic or a del sol and what code it is all it says is p3p
Re: need to know if there is such a thing as a p3p ecu? (morenoesrider)
ive heard of the p2p ecu but thats it, not that that helps at all. the search didnt bring anything up either.
Re: need to know if there is such a thing as a p3p ecu? (pat92si)
on the side of the ecu its got serial numbers and in between those numbers it says p3p i know that there is a p2p ecu but, i want to know something i have a 90 civic hatchback si, the engine was swapped for a b16a from a 94 honda del sol but im not sure if it has the ecu form the del sol or the old civic, so i want to find out how to determine that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">ECU CODES
PG6 : 88-89 Integra (all makes)
PM5 : 88-91 Civic/CRX DX
PM6 : 88-91 Civic/CRX SOHC Si
PM7 : 89-91 DOHC ZC (JDM 'EF' ECU)
PM8 : 88-91 CRX HF
PR2 : 89-91 ZC (Euro)
PR3 : 89-91 JDM B16A EF8/9
PR3 -J00 or J51 : 92 JDM Integra B16A EF8/9
PW0 : 89-91 JDM B16A EF8/9 DA6-XSi
PR4 : 90-91 Integra LS/GS
PS9 : 88-91 4 door Civic EX Auto
P05 : 92-95 OBD-1 Civic CX
P06 : 92-95 OBD-1 Civic DX
P07 : 92-95 OBD-1 Civic VX
P08 : 92-95 OBD-1 Civic D15 JDM
P0A : 94-95 OBD-1 Accord EX
P13 : 93-95 OBD-1 Prelude Vtec
P14 : 93-95 OBD-1 Prelude Si (non Vtec)
P27 : 92-95 OBD-1 EG JDM Civic 1600 sohc
P28 : 92-95 OBD-1 Civic Si/Ex
P30 : 92-95 OBD-1 DelSol DOHC Vtec Si/EG SiR
P54-G31 : 1997 Honda Accord 1.8 LS
P61 : 92-93 OBD-1 Integra GSR
P72 : 94-95 OBD-1 Integra GSR
P72 : 96-00 OBD-2 Integra GSR
P73 : 96-00 OBD-2 Integra Type-R (JDM & USDM)
P74/75: 92-95 OBD-1 Integra LS/GS
P75 : 96-00 OBD-2 Integra LS/GS
P2N : 96+ OBD-2 Civic HX Coupe
P2P : 96+ OBD-2 Civic EX Coupe
P2E : 96+ OBD-2 Civic DX Coupe
P2M : 96+ OBD-2 NZ Civic SOHC VTEC
P2T : 99+ OBD-? Civic Si Coupe
P5P : 97-00 OBD-2 Prelude Type-S (JDM ECU)
PBA : 97+ US Acura 1.6EL
PCT : 98+ JDM ITR / CTR
PCX : 99+ OBD-? S2000
PM8 : 88-91 CRX HF
Re: need to know if there is such a thing as a p3p ecu? (EGwhat!!!)
Quote, originally posted by wlee112 »
i swapped a b20 vtec head on my b16. friend told me my vtec fluid was low, but i dunno where to check it. My vtech light used to work , but when i hit 6k nothin happens! i'm not sure but someone said that oem vtech oil is the best but when i went to the dealership they had no clue wht I was taling about...
HAAAHAHAHHHHHAHAHHAHAHHHHAHAHHHHAHAHAH, thats the funnest thing i had heard in a LONG time. hahahahah ****** great.
yeah thats the hole list.
Re: need to know if there is such a thing as a p3p ecu? (Mr Hammond)
sorry, my bad i read the code wrong the last time that i took the ecu out, i still have a problem though, my vehicle wont pass emissions, its running to rich, ive replaced everything to correct the problem, except for the ecu, ive had mechanics, other shops and even emissions tell me that it is probably the ecu, now, i need to know if the pr3 for 89-91 jdm b16a is what its making it run to rich? remember the eng is from a 94 honda del sol. if anyone knows you would be a great help.
Well you are running an OBD-0 ECU in and OBD-1 car. Which won't do **** for your 4-wire O2 sensor. Also, it will not flash a CEL which is why you have none. They were stored in the ECU. That's what the peep hole is for. So you really have no working O2 signal going to the ECU so of course the car is going to run rich as ****. You need to put the correct ECU in there.
thank you so much for the information it is exactly what i needed to know, ill go get it as soon as i find it?
Frost7177
02-20-2009 03:44 PM
Blockhead G
03-25-2002 03:24 AM
