need keyy but..
I hate rap music
need keyy but..
I have a wierd VIN number.. its says it s 91, (which was the year it was made) but its a 92 Civic.. i need a key, but when i went to honda.. they couldnt make me a key.
so is ther a way to rig up like a switch to start the car? i really dont need a key, considering its a drag only car. and theres nothign to steal out of it.. thanks
take the ignition out and there's a 4 digit # on it take the # to a local locksmith they will make the key for u around 20 bucks. done it 2 times already
Re: need keyy but.. (spoonie_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonie_GSR »</TD></TR><TR><TD CLASS="quote">I have a wierd VIN number.. its says it s 91, (which was the year it was made) but its a 92 Civic.. i need a key, but when i went to honda.. they couldnt make me a key. </TD></TR></TABLE>
the VIN says 91 b/c there are production date cut offs... for xample.. like a november of 91 model would already be considered a 92.. i wouldn't know why they can't cut you the key... some counter guys are really stupid.. but I know that if you go to acura.. they have the same key codes as honda... if you find out what your key code is *xplained in the post above* they can cut u a key..
I hate rap music
ok, my friend works at honda and he is trying to cut me a key today.. if that doesnt work.. i will take the ignition number. where on the ingition can i find that number? do i have to take it out?
dont have to take it out just look at the bottom. or you can take your driver or passager door handle out the lock cylinder on the door handle also have the same 4 digit # good luck
Re: (Spugen_y0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spugen_y0 »</TD></TR><TR><TD CLASS="quote">Yes their is but you still need the key to unlock the wheel...</TD></TR></TABLE>
its its just a drag/race car the honda steering wheel locks can be broken by turning the wheel with all ur muscle powar. i havent dont this before, but heard that honda has the easiest steering wheel locks to break
so you have a M in your VIN not a N for the year?
http://www.b18c5eg.com/vins.htm
for a drag only car, you can completely remove the ignition key all together.
if you don't care about Accessory it's even easier.
A switch, a push button, a couple 30amp relays and some soldering skills is all you would need. Let me know if you want to go this way, I can track down all the wire colors and make a quick write up on how to do this for you.
spoonsports12
05-14-2008 11:38 AM
SHG_Claudio
11
05-08-2008 10:08 PM
