Need intake manifold diy
Old 08-08-2013, 12:48 PM
14psi's Avatar
Icon3 Need intake manifold diy
I really need a detailed description on how to remove the intake manifold from the head. My engine is a completely stock d16z6. Do I only have to remove the 7 studs to pull it apart enough to lift the head.
Old 08-08-2013, 12:50 PM
PHANTOM MENACE
24TEN's Avatar
Default Re: Need intake manifold diy
Yup.
Old 08-08-2013, 01:00 PM
teamXteg's Avatar
didnt you already have a thread for this??
unplug your battery.
take off your fuel line.
unplug the injectors,IACV,TPS,MAP
unhook the hoses for coolant. and the hose to the bottom of the FPR.
there is a brace bolted to the IM and the block for support.
unbolt the intake stud bolts.
loosen the throttle cable.
bam intake is loose.
if im missing anything let me know
Old 08-08-2013, 01:08 PM
B_Swapped93's Avatar
Correct^^
you'll loose some coolant also that bracket can be a pita to get undone if you don't have some good extensions.
Old 08-08-2013, 01:11 PM
PHANTOM MENACE
24TEN's Avatar
If the intention is to remove it completely from the car, then follow the directions above. And yeah, I could've swore you had a thread about this already.
Old 08-08-2013, 01:12 PM
teamXteg's Avatar
Icon4 Re: Need intake manifold diy
Originally Posted by B_Swapped93
Correct^^
agreed!! luckily i had my z6 out on the stand when i did it.. but when i did my ls/v a while back ugh.. pain
Old 08-08-2013, 01:15 PM
teamXteg's Avatar
btw i read this over again and are you just wanting to remove the IM.. if so thats the steps.. if you are wanting to remove the head and intake all in one thing.. no.. there are more steps.. just fyi
Old 08-08-2013, 01:24 PM
The Grumpiest
grumblemarc's Avatar
How about download a field service manual and stop creating threads about it? And if you say that the FSM isn't detailed enough then I can assume you require someone to do it for you while you watch from the sidelines.
Rsuave24
03-27-2014 09:14 PM
14psi
08-09-2013 08:39 AM
notnilc20
05-10-2011 10:41 PM
95gsr
10-04-2001 10:12 PM
Quick Reply: Need intake manifold diy
