Need INSTRUCTIONS for a d16z6 complete swap into a 92 DX hatch(i'm takin out my d15b7)
Old 11-15-2004, 04:25 PM
JDMbolo's Avatar
Default Need INSTRUCTIONS for a d16z6 complete swap into a 92 DX hatch(i'm takin out my d15b7)
Hey everybody..i've already searched for this but cant find anything...I need instructions for my z6 swap..i heard its really easy, but i jus want to know what are the hard parts, i dont wanna mess anything up...O yea the only thing i dont have is the z6 ecu, but i heard my car will still run wit the b7 ecu but vtec wont kick in..well jus let me know wussup
Old 11-15-2004, 04:29 PM
HT Order of Merit
JDM_Ej's Avatar
Default Re: Need INSTRUCTIONS for a d16z6 complete swap into a 92 DX hatch(i'm takin out my d15b7) (HyprEGhb
Its simple.
Same wire harness.
Add VTEC wires. VTEC Pressure and VTEC Solenoid, and the ground. EXTREMELY simple. add them to the harness, and run through the firewall under the battery. Pin them into the ECU.
http://hybrid.honda-perf.org
Check the tech section for ECU pinout locations.
When your changing the harness, LABEL the plugs and where they go. Many of the ones at the intake manifold/throttle body area are the same plugs, but if you mix them up the car will run like ***.
Old 11-15-2004, 04:34 PM
JDMbolo's Avatar
alright koo
Old 11-15-2004, 04:48 PM
Sour Diesel's Avatar
What car did you get the new motor out of?
Old 11-15-2004, 04:55 PM
2lua's Avatar
it plug and play, your car already pre vtec wired.
Old 11-15-2004, 05:58 PM
_RevHardD15's Avatar
whaaa?
Old 11-15-2004, 06:06 PM
CivicSpoon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">it plug and play, your car already pre vtec wired.</TD></TR></TABLE>
He'd still have to add the wires on the engine harness part of the plug on the shock tower. Vtec is only prewired on the firewall side part of the plug.
Old 11-15-2004, 06:21 PM
slammed_coupe's Avatar
uhh...correct me if i'm wrong but the ECU that comes with the d15b7 is non vtec ECU meaning that even if you run your vtec wires from the silenoid to the ECU your vtec wont kick in.....the only way is to get a p28 ECU cause it has vtec
Old 11-15-2004, 06:32 PM
Go Fast Civic's Avatar
he has to get a p28 ecu, the harness that runs from the ecu to under the hood is already vtec wired (on that year correct me if im wrong) he just has to run the wires from there to the sensors. so you need to go to a junk yard and get the 2 sensors you need and cut them off. heres bauley write up all you pretty much need is section #5 https://honda-tech.com/zerothread?id=635580
Old 11-15-2004, 06:41 PM
94_HATCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_coupe &raquo;</TD></TR><TR><TD CLASS="quote">uhh...correct me if i'm wrong but the ECU that comes with the d15b7 is non vtec ECU meaning that even if you run your vtec wires from the silenoid to the ECU your vtec wont kick in.....the only way is to get a p28 ECU cause it has vtec </TD></TR></TABLE>
Your right. that ecu doesnt have vtec. p28 is the one to get.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gofastcivic W &raquo;</TD></TR><TR><TD CLASS="quote">he has to get a p28 ecu, the harness that runs from the ecu to under the hood is already vtec wired (on that year correct me if im wrong) he just has to run the wires from there to the sensors. so you need to go to a junk yard and get the 2 sensors you need and cut them off. </TD></TR></TABLE>
the new sensors are already on his new engine. he doesnt need to go to the junkyard for that.
Old 11-15-2004, 09:20 PM
im sorry i was refering to connectors for the sesors hence "cut them off" of course the vtec engine will have the vtec sensors lol
Old 11-16-2004, 12:52 AM
JDMbolo's Avatar
So this means i cannot use the b7 ecu at all right?....but will my car still be able to run until i get the right ecu
Old 11-16-2004, 04:49 AM
nsxmatt's Avatar
Default Re: (HyprEGhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyprEGhb &raquo;</TD></TR><TR><TD CLASS="quote">So this means i cannot use the b7 ecu at all right?....but will my car still be able to run until i get the right ecu</TD></TR></TABLE>
Yes, it will still run with that ecu. Best bet it to find a Z6 harness and use it, then it's plug and plan. No wiring.
Old 11-16-2004, 04:58 AM
Default Re: (nsxmatt)
yeah your car will run, not that great but it will run. he dont need the whole harness. he just needs 2 clips off of a civic ex harness or si hatch, then he has to solder 3 wires(very easy).
Old 11-16-2004, 05:10 AM
JDMbolo's Avatar
alright thanx
Old 11-16-2004, 07:22 AM
SOHC_Brian's Avatar
talk to the uberdata guys. when i was reading about chipping the p28, i think i read that u could chip ur current non-vtec ecu to perform like a p28 with vtec and stuff.
Stanceman
11
12-07-2017 10:02 PM
1sickeg8
16
01-10-2010 03:18 PM
heffnerp97
01-01-2009 08:05 PM
yusoslo
08-18-2004 10:25 AM
yusoslo
04-19-2004 09:47 AM
Quick Reply: Need INSTRUCTIONS for a d16z6 complete swap into a 92 DX hatch(i'm takin out my d15b7)
