need help y8 into 00dx
Old 07-07-2010, 05:29 AM
bluelsvtecda9's Avatar
Default need help y8 into 00dx
I recently dropped a 96-98 y8 into my 00 dx coupe. I used a 99-00 auto ex harness and converted the iacv to a two plug. So now i want to know how to run the second o2 sensor. I need the pinouts and a pic showing where.
Old 07-07-2010, 05:38 AM
Former User's Avatar
Default Re: need help y8 into 00dx
http://www.phearable.net/tech/
http://technet.ff-squad.com/
Old 07-07-2010, 06:48 AM
thanks but any better write up steps on doing it
Old 07-07-2010, 07:00 AM
apexi_rsx's Avatar
the harness should have 2 O2 sensors its a obd2 car all of them have 2 02 sensors but i think in ex's they were integrated in the floor harness.if you used a dx harness u would have had both and just had to wire vtec and knock sensor and 2 wire IACV.
Old 07-07-2010, 07:16 AM
titi_vtec's Avatar
if you will put from auto to standar i can take pic from mine that i did, i will show u what cable u have to cut and wich one u have to link on the ecu, for use the auto harness, and need new intake manifold because your IACV is different, and throttle body too, i did this stuff like a week ago so i can help you, but 99-00 harness, ecuand motor are different to 96-97-98
Old 07-07-2010, 01:19 PM
well i used a auto ex harness did the iacv conversion. i looked at the pinouts i seen pin 8 and 23 are for second o2. now im lost where would the other two wires go? its a 4wire o2 also correct?
Old 07-07-2010, 01:36 PM
The other two wires are power to the O2 sensor heater element (from fuse 15 on Blk/Yel wire) and ground to the O2 sensor (from Grn/Blk wire; not pinned to ECU).
Old 07-07-2010, 02:22 PM
damn your a beast thanks alot. Can i run them to from the other o2 being i still have y7 exhaust manifold and they are close
brentl21
02-19-2016 12:14 PM
Euro-R82005
10-15-2015 05:43 AM
allanjr350
10
07-02-2015 08:26 PM
jeremy3131
11-10-2010 03:44 PM
My JDM EJ8
17
12-19-2008 06:08 PM
Quick Reply: need help y8 into 00dx
