need help wiring up
need help wiring up
im trying to wire up my power windows doors locks and mirrors, i have the harness, but im having a lot of trouble, as i am horrible with wiring.
if anyone has done this conversion, and is willing to help me, PM me. im in san diego, and i need to finish this soon.
Re: need help wiring up (blackhatchy)
its a 97 hb. and i got no helms i know i should have one, but i dont. try not to give me any bs, just help.
Re: need help wiring up (JUN EK9)
Do you have the EX main chassis firewall harness ?
I believe you have to remove the dash..I had a friend who did this swap in his 00 EK.
Re: need help wiring up (poison)
the wiring doesnt even go under the dash. its just the 2000 ex harness doesnt plug up to my 97 hb when the wiring goes thru the back seats.. it will plug into my fuse box and all of that just fine. but i think i need to cut and resolder some of the wires to make it work right
Your best bet is to search around archived then, and verify wires, and wire the configuration to a stock 96-98 Civic EX, then.
i've searched those. not much help.
was there any major wiring changes from 96-98 to 99-00??
Man, you seem to have made this more confusing than I had. All I did was swap to 2000 Si doors, which is almost the same as you. Then my buddy took the stock harness from the door and cut the plug off and ran the wires under the dash. He used a wiring diagram to see which wires would connect to what in relation to the wires under the dash and the wires he ran from the door. Sorry I didn't do this first hand but it took him less than two hours. Any good audio/security shop should be able to do this for you.
Re: need help wiring up (Pho Real)
but i dont got a buddy like that. nor do i have a diagram. because i thought it was all going to be plug and play
i dont care if its ghetto or not or whatever. i just want it to be done and over with.
and im having trouble with the drivers side door lock. i put it in right, but its not working right. and all these problems are really getting to me.
does anyone know if there are any big wiring changes from 96-98, to 99-00? cuz im going to cut and resolder all the wires so the color matches up. and i dont want to realize that i hooked up all the wires to all the wrong spots and make my car blow up or something.
DHGsRaphael
09-10-2014 08:38 PM
enot767
12
07-17-2009 02:27 PM
spoink
05-17-2006 03:50 PM
