Need help with wires
There are 5 plugs that are left to connect on my first gen b16 into a 5g(95 ex) civic. Please guide me to where they go.
Plugs on wiring harness
1. MAP sensor plug (i thought map sensor was by the fuel filter??)
2. Purge Control Solenoid
3. Elect air Ctrl valve solenoid
4. A Single yellow wire with green stripe
5. Plug with a green and a black wire(i think this is water temp).
There is a sensor on the back of the intake manifold(not the tps) that isn't pluged up.
The two top sensors(knock, which 5g civics don't have, and water temp i think) don't have a matching plug.
[Modified by fire7882, 7:02 PM 6/28/2002]
Re: Need help with wires (fire7882)
the single wire goes to the oil pressure gauge located to the left of the oil filter, for the water temp you would have to get the second gen water neck, or rig it to the sensor above the the oil pressuse gauge since it's a first gen, it doesn't matter which goes where as long as they're connected, and the map sensor is on top of the throttle body
