Need help on tire size
Does anybody know what size tire I should run oN my ej. It's slammed on some coils in the front and springs on the rear. I just got some 15s from a friend and te tire size is 195-65-15, anybody think that would fit or should I go smaller tire size? Let me know guys I want to put these oN I'm tired of riding on steelies
Re: Need help on tire size
I run 205/50/15 and my car is lowered a bit, 1.5-2 inches. I think 195/65 will be too tall, 195/55 will be about the same height as the steelies and as 205/50.
It's definitely taller than stock by at least 35 mm so if they fit your speedo will read wrong, but you can raise your car like Hill4589 said and/or just try it, wheels are easy to change.
Not slammed, I don't care for a car thats slammed. I lowered roughly 2" on the front and 1 3/4" on the rear.
65 series tires will be too poofy, even the stock teggy tires that come on the GsR are 195 55/15.
Most do the 195 50/15 or 205 50/15.
Why do I get this feeling that the only reason that your looking at 195 65/15 is because their cheap???
Lol I'm only asking about the 195/65/15 because there were free.I'm a just try them if they look weird or rub I'll just get some smaller tires
It's going to look funny with a 195/65/15, especially if you're going to try to dump it. I ride on 15s, one set has 205/50/15s (SI wheels) the other set has 195/50/15s (GSR wheels) and they both look great. I did have them on my Integra and slammed the hell out of it and it looked amazing, it just rode like crap.
From the wheel/tire FAQ:
For a CRX, del sol, del sol Si, or pre-'96 Civic, the following sizes are usually best:
13" - 175/70-13
14" - 185/60-14, 195/55-14
15" - 195/50-15
16" - 205/40-16, 195/45-16
These are the "correct" sizes for your car even though many people run 205/50 and 195/55 without problems. the 195/65 you have will not fit and are not the right tire for your vehicle. the narrower 195 will probably be better for a "slammed" setup as it will give you more clearance to "tuck" the tire if thats what your into
13" - 175/70-13
15" - 195/50-15
i put 195/55/15 on mine one time (cause they were free) and those were too "poofy"
195/65 would be over kill i think
do it right, make it look right.
