need help taking out the rotor (need to finish before it gets dark)
I am changing rotors in my civic. I took out brake assembly but I can't take out rotors. After i take out two screws in rotors do I need to take out big bolt in the center to take out rotors?
Please help me out.
thanks guys
Please help me out.
thanks guys
No you don't need to take the axle nut off
u need to thread some bolts into the other 2 holes on your rotors, the ones the screws didn't come out of this will push the rotor off or some light tapping with a hammershould break them lose, they are probably rusted to the hub
Re: (egsleepercivic)
make sure you have an impact screwdriver to remove the two screws holding on the rotor, they usually have loc-tite on them from the factory. if you stip them you will have to drill and that my friend sucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic »</TD></TR><TR><TD CLASS="quote">No you don't need to take the axle nut off
u need to thread some bolts into the other 2 holes on your rotors, the ones the screws didn't come out of this will push the rotor off or some light tapping with a hammershould break them lose, they are probably rusted to the hub</TD></TR></TABLE>
I hammered but let me try to thread some bolts into the other 2 holes on rotors.
Re: (dohcdelsol93)
sometimes you have to hammer hard, like it stole something from ya. when they rust they don't want to part, water + heat = stuck
Re: (spyderracing32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spyderracing32 »</TD></TR><TR><TD CLASS="quote">Beat that thing like it stole your money. You're not going to hurt it.</TD></TR></TABLE>
bullshit. youll might damage the wheel bearing.
use a bolt that fits the 2 holes and screw them until it break loose.
Re: (=GAMEOVER=)
you dont need to hit the rotors hard, and use a rubber faced dead blow to hit the outer rotor or brass faced and hit the inside between the studs, if they dont come loose with minimal hitting, thread the bolts in until they hit the hub and force the rotor out.
Re: (=GAMEOVER=)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =GAMEOVER= »</TD></TR><TR><TD CLASS="quote">
use a bolt that fits the 2 holes and screw them until it break loose.</TD></TR></TABLE>
Thanks guys for your help.
Like this guy said, I used 2 screw and it took less then minute to take it out. I was hammering really hard before and that was stupid idea.
I was able to change only one because I got dark outside and cold.
Is it ok if I change other one next weekend? I am going to put around 400 miles.
Re: (Jaydeep)
i wouldnt wait man it only takes a few minutes to change rotors and pads do it tommorow. when u get off work or out of algebra class.
Re: (pane93civhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pane93civhb »</TD></TR><TR><TD CLASS="quote">i wouldnt wait man it only takes a few minutes to change rotors and pads do it tommorow. when u get off work or out of algebra class. </TD></TR></TABLE>
My work is hour from my apprtment so by the time I get to my appartment its 7:00 PM and its dark-cold. But what will happen if I wait till next weekend.?
rus
11
06-05-2006 12:01 PM
88crxhfb16
45
06-24-2005 07:38 AM
