need help on a swap!!!!??????
New User
I'm new to the Civic scene...so take easy on my.......
I just completed swapping a '92 D16Z6 vtec into my 92 Civic CX. (GSR are too rare and expensive). Will bolt a Greddy turbo next..
The only problem is It will not start, engine turns, I have sparks (could see "lightning" when starting with spark plugs out) fuel pump ok, ecu connected,injectors ok...
anybody have any ideas before I start testing each sensor I got on there????????
Re: need help on a swap!!!!?????? (92Si mets)
did you touch the ignition, or cam timing at all?
just go through, and make sure everything is correctly pluged in for starters.
fuel pump is coming on right?
flipstar760
01-17-2006 04:03 PM
