Need help with spring rates!!!! ASAP
Old 07-23-2001, 12:07 AM
Banned
d0nkeyxPunch's Avatar
Default Need help with spring rates!!!! ASAP
I have a 00 Honda Civic Si and I'm about to get Ground Control. I was told that they offer custon spring rates. I have a KYB AGXs and I'm confused on the spring rates. I was thinking about 650 lbs in front and 800 in rear. Would this be too stiff that it will blow out my shocks? I want to go Auto-X and I'm tired off "body rolls" when I take turns. I want the stiffest spring rate that I could have without damaging my shocks. PLEASE HELP ME!! thanks.
Old 07-23-2001, 08:54 AM
New User
deviant94ex's Avatar
Default Re: Need help with spring rates!!!! ASAP (FastxCivic)
WOW.....650/800 is really stiff.....i mean really stiff. if you want to keep any street drivability....that is...not have your teeth fall out from the harsh ride then i would go with the integra rates. from what i have heard they are a bit stiffer than the normal rates used for a civic and offer better handling with only a slightlty harsher ride than regular ground control springs for a civic. to help with that body roll try getting a good rear sway bar, strut tower bars, and a rear lower tie bar. also, putting the AGX's on the stiffest setting during auto-x will help as well. good luck.
CHRIS
Old 07-23-2001, 08:58 AM
eviladam's Avatar
i've heard 400 is about as high as you'll be able to go on KYB AGX's to stay fairly reliable.
Old 07-23-2001, 03:44 PM
spoonek4's Avatar
Front 8kg/mm rear 6kg/mm will be more idea for sports driving and front 10~12kg/mm and rear 8~10kg/mm will be quite ideal for more lapping days event and stuff.
I'd rather get Kg/mm DR Racing springs instead of GC coilover springs. I used them before they are just really nice on street and circuit http://www.aj-racing.com http://www.kgm.co.jp
Feel free to contact me at spoonek4@hotmail.com if u need more info on those.
Old 07-23-2001, 05:55 PM
New User
sshotrr's Avatar
Default Re: Need help with spring rates!!!! ASAP (spoonek4)
Remember if you go with a anti sway bar it may move you into a more competitive class.
DougNuts
Suspension & Brakes
11
06-12-2006 09:47 AM
mr_mbuna
02-20-2003 01:50 PM
comptechgsr
05-31-2002 03:06 PM
The Punisher
04-19-2002 07:12 PM
EL-Driver
12-05-2001 08:47 PM
Quick Reply: Need help with spring rates!!!! ASAP
