Need help with a no start!
I need help trying to figure out whats causing my car not to start. I have a '92 Civic VX 1.5L and Sunday it was just idling in the garage when it just quit. It cranks but no start. I replaced the Main Relay ($60) that controls the fuel pump & ECU still nothing, then put a new cap & coil on, and still nothing. The one thing I haven't replaced is the Igniter yet because of the cost ($95). Is there anyway to test it to be sure it's bad?
Any suggestions would be appreciated. https://honda-tech.com/forums/images...es/emdgust.gif |
Re: Need help with a no start! (sivicman)
engine grounding wires? battery? Alternator?
Are you sure its getting fuel?
your answer:
https://honda-tech.com/zerothread?id=738752 |
Re: Need help with a no start! (FrostySol)
I put a new coil on still no spark. Battery is fine, and fuel is coming out of fuel filter.
I just cracked open the fitting at the filter to see if I was really getting fuel. You think it might be an igniter? Thanks |
Replace all your engine grounds. thats what fixed my problem with the car not starting
see my post in the link above. Test the ICM, if it's broke, get a new one, if not check your grounds https://honda-tech.com/forums/images/smilies/emthup.gif
I finally found out what was causing the no start. The ground wires that bolt to the thermostat housing where loose. I noticed the CEL light was dim with the key in the "on" position and fiqured it must be a ground problem. So I spent $60 for the relay for nothing, but now I know for future referance.
Thanks for everyones help, everyones suggestions where greatly appreciated. https://honda-tech.com/forums/images/smilies/emthup.gif |
