Need help with jdm eg cluster
I just install my cluster in my 93 ex coupe, everything works fine except for the fuel and dimmer switch (lights up but i cant adjust the brightness of it) can anyone help me with this problem.
fuel isn't going to work cause your car doesn't come equipped with a low fuel indicator, and the dimmer switch won't work cause jdm egs don't have dimmer switches
Re: (FastAssEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastAssEG »</TD></TR><TR><TD CLASS="quote">not the fuel light the fuel gauge it just stays on empty</TD></TR></TABLE>
Maybe you're just out of gas? Anyway, that is strange. The only things that don't work on mine are the dimmer, gas light, and the thing that lights up if you open the doors. But, none of those are supposed to work anyway.
Re: (Cornbread Jr.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cornbread Jr. »</TD></TR><TR><TD CLASS="quote">
Maybe you're just out of gas? Anyway, that is strange. The only things that don't work on mine are the dimmer, gas light, and the thing that lights up if you open the doors. But, none of those are supposed to work anyway.</TD></TR></TABLE>
(this is jdm eg2 at my friends house) same with mine but the i have a full tank and we tried it in my friends car and it read all the way full and he didnt have a full tank.
Re: (Cornbread Jr.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cornbread Jr. »</TD></TR><TR><TD CLASS="quote">Maybe it's just a bad cluster.</TD></TR></TABLE>
so theres no wireing requied?
Re: (JDM EG2)
my fuel works good, but my tach doesn't work. cant figure it out. dimmer also does not work.......
everyone i know who has one, the dimmer doesnt work, but a little 127 should fix that right up.
Re: (ridiculous)
JDM clusters don't have a dimming option, its been said a few times up above...
<--looking for a EG6 cluster, where have you guys gotten yours from??
Re: (JDM EG2)
no, no wiring is required for the fuel gauge to work. I've had 2 different jdm clusters and both fuel worked fine, just the low fuel gauge didn't work of course, the dimmer. Everything else worked without any problems. Ebay is where i got mine from.
Re: (SloCivicHMM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloCivicHMM »</TD></TR><TR><TD CLASS="quote">
<--looking for a EG6 cluster, where have you guys gotten yours from??</TD></TR></TABLE>
http://www.hmotorsonline.com/s...20001 <--click
Re: Need help with jdm eg cluster (JDM EG2)
they can be pretty delicate and the fuel needle may have broken.
check all bulbs & make sure they all light up. You dont need the dimmer.
Anyone wonder what the hell the dimmer is there for anyways...? (US Spec)
Re: Need help with jdm eg cluster (gumtape_deathmatch)
anyone know why my tach wouldnt work, what should i check? it just kinda bounced around, idles at 4k or so, just never correct.
in japan they dont have dimmer switches ..so in that area your cluster works fine...as far as the fuel thing...if you look like 5 threads up there is another guy withthe same problem..pay attention to this thread for future answers to your problem
Re: Need help with jdm eg cluster (Grip Driver)
i was reading somewhere that i can swap out the fuel gauge mechanism out of my old cluster into the jdm one and it will work fine
has anyone heard of doing this?
Manolo
13
10-03-2005 08:31 AM
JDM_Ej
08-11-2005 04:05 PM
