need help, installing a gsr cluster into a eg PLEASE!!
ok, i followed this link and did EVERYTHING exactly the way it said in the diagram http://www.geocities.com/cinq112/gsrclusterswap.html but nothing freaking works!!! the only thing that works on the damn thing is the left and right turn signals and the high beam light indicator, nothing else, do you think my wiring is bad or the integra ends that i have are bad, i just sliced and twisted the wires together and put eletrical tape over them, is this not good enough for these kinds of wires, and does anyone else have a different diagram from the one on this site??
Re: need help, installing a gsr cluster into a eg PLEASE!! (Jdmb18c)
I'm in the process of putting a 96 GSR cluster in my VX right now. I will compare the chart on that page to my Helms manuals and see if there are any wrong pinouts. Splicing and tape isn't as great as soldering and using heat shrink tubing but it will make a connection for sure. Sounds to me like the chart is probably wrong.
Re: need help, installing a gsr cluster into a eg PLEASE!! (VTECVillain)
ok thanks, well just let me know if you see any differences between the two
someone trade me dashes! i have a teg dash with the wring harness converted. located in phoenix! i miss my old eh dash
here.. ill share all my secrets once agian.. here is a wiring harness diagram that will work.. i know it works cause i have done it in my car..
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
match the color wire and function from the intregra harness to the civic harness..
if you got any problems after that email me, IM, AIM me and ill try to help you out.. you WILL have extra wires at the end of the install just to let you know..
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
Re: need help, installing a gsr cluster into a eg PLEASE!! (95CivicEX)
THANKYOU!!!!
i was just about to put the freakin civic one back in, ill check this out on how it compares to the other diagram i have, thanks again
to you
to you
your welcome.. the diagram i gave you has been posted on honda-tech.com by me many times.. and i know it works cause i have installed a gsr dash into my eg and it works fine.. so if you have any problems its errors on your side..
everything works perfect, thankyou man, that other site was crap, nothing was right, thanks again
no problem man.. good to see you got it all working, thats what honda-tech.com is here for, to help others.. if you got a digi cam put some pics up so i can see how it turned out.. sometimes i want to go back and fix mine a little bit cause i cut too much w/ the dremal tool...
*edit* btw here is a picture of mine complete, installed and working..
[IMG] [/IMG]
duh.. imagestation isnt working now.. will post pic later if your interested..
[Modified by 95CivicEX, 10:15 AM 4/11/2002]
JDM*BUBBLE
03-29-2004 04:48 PM
racecarpete
03-26-2002 09:00 AM
