need help identifying these wires
I'm finishing up my wire tuck on my ek and i unraveled a part of the harness and seen these cut wires. harness is from a 99-00 civic ex m/t. it was off a running car with no cels. (i noticed the o2 sensor plug and injectors had been cut and re-soldered) the harness has been molested. now i am trying to figure out the following wires
white/red
brown/black
shielded red/blue
shielded blue/red
TIA
white/red
brown/black
shielded red/blue
shielded blue/red
TIA
Re: need help identifying these wires
off the bat I'd say knock or oil pressure maybe one of the alt plugs can you confirm what plugs you do have that are in that area maybe IACV.
it splits off the injector and alternator branch. i have iat,map,tps,iacv,inejctors,oil pressure,4wire alt plug and wire,dizzy,ect,temp send. unit, vtec, vtec press., coolant fan switch, o2, secondary o2 is in the car. i cant think of anything i'm missing.
thank you so much. i forgot to say the ckf sensor was bypassed at the ecu. thanks again!
rustlude87
11-01-2009 05:50 AM
