need help guys
need help guys
i have 2 questions:
1) what are those 2 hole for?
those came with the intake:
2) with 17"inch rims how much should i drop my car?
i have 1995 civic coupe ex if that helps
help me out guys thanks
Re: need help guys (S14-Civic)
One is for the Sensor, and connect to the line to the engine block near the top, u can connect the line to the block, or take the line off and just put 2 oil brethers on each side, for show
and that one big cap thing, is used to cover the extra hole.
i would close the farther one, so u don't have to strech ur sensor so far to plug it in, those small things go in the hole, so the sensor will fit right in, and be sung.
Re: need help guys (Quad-Damge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge »</TD></TR><TR><TD CLASS="quote">
and that one big cap thing, is used to cover the extra hole.</TD></TR></TABLE>
I...didn't have an extra....hole?
Just look at your stock intake arm, you are basically hooking the same things up.
ThinkRevolution
01-02-2011 09:43 AM
tRaCeYoUiNcHaLk
04-25-2007 08:47 PM
