need help getting a inner shaft joint
hi all, so im needing a new inner shaft joint for the left hand side, think thats the name for it? you know the flexi joint that connects to the gearbox, not the c.v joint at the wheel
the guy in the shop said theirs a few differant types so i should get the diameter and number of teeth on it, the car is a 93 del sol sir with a jdm b16a engine so if anyone knows this please tell me! thanks
Re: need help getting a inner shaft joint
really? **** thats a pain! so i got to get the hole shaft with the joint on the end, would i have to get a c.v joint seperate? i replaced just the c.v joint before so i thought you could do the same with the inner part
in order to replace the inner joint. the axle needs to be taken out anyways, so why not just replace it. make it easier on yourself.
OmgDelSol
09-10-2014 02:16 PM
Coomer
07-06-2007 11:02 PM
