Need Help:EK 1.5 exi auto to B16A manual.
Need Help.I want to swap a Manual B16A engine in a EK(Sedan) with 1.5l auto engine.Can i use the EG9 pedal set and (B16)engine mounting found on the rear cross?Are there any consequent mods i'll have to make?Waiting for your advice,thank you.
pm4nudes
Re: Need Help:EK 1.5 exi auto to B16A manual.
you can use any pedal set you want. you can even mod a spoon and fork as pedals. but yea I believe my friend picked parts from an eg for his swap.
its gonna take a bit of effort and money.
easiest method is grabbing the entire engine, ecu, and dashboard harnesses from the automatic car, making a custom tranny mount, and modifying the floor to accept the auto shifter.
you have a lot of work ahead of you.
it is MUCH cheaper and easier to sell the car and buy an automatic chassis.
trust me. been there done that, something I wont repeat
http://www.hamotorsports.com/49520mount.html
you will need the shift linkage for b series and manual shifter and a little cutting/ drilling to the shifter tunnel, run clutch lines, pedals, etc. Decent amount of work but doable if you really want to keep your chassis.
Seagull Management
oh ****
must have been really tired last night, read this as a manual going to a auto
my bad
auto to manual swaps are easy! hardest part is shaving the auto shift cable bracket/floor piece and jbh-welding or siliconing a flat piece there
my bad
just use the ek manual mounts. bolts right in.
i believe the eg pedal set will work just fine. only differences will be clutch line and a few other things but are all easily surmountable problems.
have fun
have fun
94-01 integra and 92-00 civics all share pedal fitment. only difference is throttle cable sizing and fitment on the pedal. simple enough to deal with
I have everything needed to make the swap as i've purchased an EG6/9 front cut.Concerning the mounting found on A/T gearbox(EXI 1.5L) and where it is bolt on the chassis,are there any mods required to fix a M/T gearbox mounting on the chassis?
uenolove
02-27-2008 04:32 PM
