need help on a couple of things on my eg
Well yesterday i was driving and clutch felt normal...meaning where it engages seemed at the right height or maybe a lil too high but pretty perfect.. today it goes all the way to the floor before it engages.. how do i fix this.. what is the prob?fluid leaks from the clutch pedal also..
and also are hx wheels 14"s ...basically the exact same as vx wheels but 1 inch larger right?
thanks,Randy
thanks,Randy
Re: need help on a couple of things on my eg (95integragsr1984)
fluid leaks are never a good sign.....check the clutch master cylinder and your lines for the leak......i can put $10 on it that you have air in the system, hence the clutch performance
as for the HX wheels, yes they are 14" wheels.......they weigh 12.5lbs and are made by enkie, just like the 13" vx wheels.......the only problem with these wheels is the brake clearance, but if you're running the stock 9.3"? brake system, you'll be fine
Dazer 1991
08-15-2012 08:12 PM
Yak BallZ
18
02-10-2005 05:13 PM
