need help with cooling system, anyone?
i havea 92 civic 4 door with a 96 ls motor, today i was sitting at the light going home and i see smoke and noticed it was anti freeze right away, i pulled over and was in the parking lot all night tring to figure out what it could be... it happened somewhere behind the block, like under the intake manifold, but couldnt see where it came from, i inspected all the hoses and couldnt find any holes, and my antifreeze is now all gone... need help anywhere else to look? besides hoses
Re: need help with cooling system, anyone? (ON-THE-FLOOR4DOOR)
well whenever you are free in the daytime, fill up the radiator and let it run for a while and check if you can see a visual leak.
ok well today i hookd up all the hoses and put some water in the rad and let it run for 30 minutes and took it for a ride around, and its ok... what coulda happened all the hoses appeared to be on good, and none of them had holes... i would rather just a hose pop so i coulda fixed it instead of not knowing whats going on cuz it might happeend while driving...
1 Post
water pump, its on the drivers side of the motor and will make it look like the leak is coming from behind the timing belt cover.
found it, im happy as hell now i know atleast i fixed it... it was this little hose that goes from under the front passenger side of the valve cover to the pipes that go into the aftermarket intake... a lil *** ******* hose... fucked me up...
88fourdoor
03-04-2011 03:59 PM
