NEED HELP CONVERT B16A OBD0 TO OBD1
I RECENTLY PURCHASED A 94 CX HATCH FROM A KID DOWN IN NEWYORK PAID 1100 FOR THE CAR IT HAD A B16 INSTALLED ALREADY I HAD THE CAR TOWED HOME AND WENT TOP TOP TO BOTTOM CHECKING EVERYTHING OUT FOUND OUT THAT THE FRAME WAS SPLIT SO BODY OF THE CAR IS USELESS I PURCHASED ANOTHER SHELL AND AS I WAS PULLING THE MOTOR I REALIZED THAT IT WAS A OBDO MOTOR THEY HAD COMPLETELY HACKED THE ENGINE HARNESS AND MAIN HARNESS IN THE CAR TO INSTALL IT HERES MY DILEMA I HAVE A COMPLETE HATCH OBD1 AND A B16A OBDO MOTOR WITH NO ENGINE HARNESS WHAT WOULD IT TAKE TO CONVERT THE MOTOR TO OBD1 SENSORS ETC THE CAR HAS A OBD1 DIZZY ALREADY AND I HAVE A 95 CIVIC SI HATCH ENGINE HARNESS AND A 94 GSR COMPUTER IS THIS EVEN POSSIBLE ANY HELP WILL BE GREATLY APPRECIATED
Re: NEED HELP CONVERT B16A OBD0 TO OBD1 (steve6025)
they do make conversion harnesses for OBD0 ---> OBD1.
other then the dizzy i THINK that is all you need, but i am not too sure on that.
Re: NEED HELP CONVERT B16A OBD0 TO OBD1 (alleyezonme)
i know about the conversion harness what i would like is to make the motor obd1 not the wiring i may not understand so corect me if i sound stupid what is the diffrences between obd0 b16 sensors wiring injectors etc stuff like that i am starting with out a engine harness at this point just motor sensors and injectors
HT Order of Merit
You dont need one. Im pretty sure an OBD1 engine harness will plug right in to your motor and you will be good... if this is NOT the case, yes they do make OBD0 to OBD1 conversion harnesses.
Re: NEED HELP CONVERT B16A OBD0 TO OBD1 (JDM_Ej)
do you live in easthartford i install carpet for a living and i could have sworn i seen that car in back yard of house next to apartment i worked in
TurboSiCoupe
10
02-01-2003 07:10 PM
PrecisionH23a
09-17-2002 07:18 PM
