Need help on brakes from 99 Si to 95 ex
Hey fellas, I did a search on this and came up pretty much empty handed. I was wondering if any of the brakes, calipers and anything from the suspension down from a 99-00 Si would fit on a 95 ex coupe. Since my car recently got wrecked and I'm trying to use and sell as many parts off my car before it gets sent to the junk yard. So if any info you fellas could give it would be much appreciated. Plus any modifications that would require to make them fit. Thanks in advance.
Re: Need help on brakes from 99 Si to 95 ex (EK9Civic)
You can bolt the 99si brakes onto your car without a problem. Just reuse your LCAs (I believe the 95 exs LCAs are shorter).
Re: Need help on brakes from 99 Si to 95 ex (Ricey McRicerton)
Yeah d00d, I have the whole front and rear brakes on my Si. I just need to know how much from my Si I could put on my sisters ex. So only the rear and not the front huh.
the whole knuckle from the si into the ex (I wouldn't cause you have an ex and the front brakes are the same size) just sell the nuckle and get some pocket cash.
The rear control arm off the si into the ex and now you have disk brakes.
Also I believe you will need a 4040porportioning valve also.
Declectic
Honda Civic (2006 - 2015)
21
05-05-2006 04:55 PM
