In need of help badly
my buddy was driving to work and his car died, 95 dx coupe, his vafc went dead he's getting no spark,and his getting no fuel, but the car still trys to crank over and all other electrics work... any ideas to what could be the problem? Bad ground? we checked the fuses and swapped ECU's nothing changed
Not real good with after market electrical, but I would check the vafc ground.
Is there any way to remove the vafc and see if it will start ? IDK
I would also repalce the dizzy, could be a ignitor or coil. remember the OEM dizzy it 13 y/o.
no fuel, hhuummm???
Clean the ECU ground, it's attached to the thermostat housing, clean it real good. Another guy here had the same problem, he cleaned it twice before it would start.
good luck
Modified by 1992Si at 11:31 AM 7/19/2008
no fuel, hhuummm???
good luck
b18cEK
07-13-2004 09:25 AM
Sirex
04-16-2003 05:17 AM
