Need help B16a SIRII vs B16B / For eg hatch
ok im getting a motor in 3 weeks i have $3500 i dont know what to get either the b16b or b16a if i get the a im def getting the lsd trans for an extra $300 from hmotors prices are as follow B16a $2800 shipped complete change over with lsd trans. B16b $3500 shipped .
Ok another question if i get the B16B what do i need to make it run in the eg hatch its a SI by the way do i need mounts harnest convert the ecu to obd1?
thanks in advance.
thanks in advance.
Re: Need help B16a SIRII vs B16B / For eg hatch
Get the OBD1 B16A, the B16B is more powerfull but for $700 more its a waste. If you get the OBD1 B16A you dont need a new harness, you can use the Si harness fully. Although if you have the coin and you like to talk about what you have under the hood then get the B16B I guess. For that money you could probably get a B18C hey?
You will need b-series: Mounts, Axles, Shift linkage (hydro trans linkage), Keep your P28 but get Hondata or maybe a quick Phearable.com program. If you get the B16B, you'll need all that and a OBD2-OBD1 conversion harness.
it probably does, i just made a list you can check back on. Go to their site and see if you get everything I listed.
Louie
03-06-2008 06:50 AM
