need help asap...please
New User
ok i put a motor in my car over the weekend. it's the same motor that came out(d15b7). ok i got it in fine. now it won't run for sh*t. i'm sure that i got all the plugs plugged up. and all the vaccums. now the problem is this. whenever the car gets even slightly warm it floods itself out. i'm guessing a sensor, but have no idea which one.. any help would be more than appreciated.
Re: need help asap...please (swtcivic93)
Hey dude, call a honda dealership and ask them they will at least tell you what the possibilites are, I would hope anyway.
New User
Re: Is the... (DragIIcivic)
eternal: the check engine light comes on and off. it's kinda sparatic.
dragk i had someone else tell me that so i took the one off my old engine which ran fine. it made a differerence at first then it just started doing the same thing. man i appreciate the help. any more suggestions??
Re: Is the... (swtcivic93)
i *THINK* the code is how many times the check engine light blinks when you turn engine
im probably wrong tho still learning but thats what i remember hearing
Guys, don't forget that if he swapped his engine out, the ECU is programmed to provide the correct amount of fuel and air for the smaller engine, so it may be trying to overcompensate because of the increased amount of air. Also, I think you guys have done a great job by suggesting that he check his sensors first. the O2 sensor is by far one of the most important. Another way to check if the O2 sensor is bad is by smelling the exhaust. "Rotten eggs" is the description of choice. The smell of improper fuel/air mixture will give it away. Hope this helps.
New User
Re: Is the... (TurnerMan)
ok guys......i called my local honda dealership and talked to a service guy. i told him the problem....he told me to swap the distributor. i did that and everything is fine. i don't know what the deal was. but anyways thanks for everyone's help.
Stylinhonda
09-26-2005 09:23 PM
fullraceacura
03-30-2005 06:15 PM
