need help asap o2 sensor
Old 01-30-2002, 09:27 PM
New User
b18c-93's Avatar
Default need help asap o2 sensor
just did swap in a 92 civic hatch cx with b16a i wanna put a 4 wire o2 sensor because wright it has only 1 wire can any body here help out. the reasone why is because i am using a 95 gsr ecu and its reading 02 heater because there is no heater.
Old 01-31-2002, 12:48 AM
onefastcx's Avatar
Default Re: need help asap o2 sensor (93gsb16a)
why are u using a gsr ecu that will not work so well because the gsr has the dual butterfly intake manifold so therfore if you are useing the stock or even type r intake manifold you are actully losing power just get a p30 ecu it is obd1 and it redlines at 8200 the you will have more power
GOOD LUCK
lamafia781
12-06-2009 08:22 AM
lCHaCHeel
05-04-2007 06:53 PM
.adam.
07-09-2006 12:40 PM
Jose-aka-Pedro
05-30-2006 03:57 PM
djtony5
03-08-2006 09:47 AM
Quick Reply: need help asap o2 sensor
