need help asap
need help asap
i got a 92 cx i dont know what the hell happend was racing a crx and when i stopped a cloud of smoke popped out of my hood i cant get my car into any gear (wont rive in any gear) whatsoever engine runs fine but wont go into any gear........... any help would be much appreciated so i can this fixed
_______
_______
Re: need help asap (deepnite)
Visual Inspection
Inside the car:
Freedom of shifter movement
Freedom of clutch movement
Engine torquing on shifter
Under the hood
Linkage (worn, loose, bent missing, obstructed)
Motor/Transmission mounts
Oil level
Driveline condition
Static Shift Test
Shift the transmission with the engine off and the clutch pedal depressed (clutch disengaged)
Determines if the shift mechanism and synchronizers are malfunctioning
Move on to dynamic test after this
Dynamic Shift Test
Determines malfunctioning parts in the clutch system, shift mechanism, and synchronizers
Press the clutch pedal to the floor (disengages clutch)
Start engine and allow idling in neutral
Note any unusual noises
Press clutch pedal to the floor (disengage clutch)
Shift into reverse
Engage the clutch and start to move a short distance
Note and abnormal clutch operation or shifting
Press clutch pedal to the floor (disengage)
Shift into first
Engage the clutch and move a short distance
Note unusual noises
Repeat for all gears
Clutch Spin Down
If the static or dynamic shift test identifies shifting problems, a clutch spin down test should be performed
Disengage the clutch and shift into neutral
Engage the clutch and allow the transmission to spin for a few seconds
Disengage the clutch and count for 5 seconds, and then engage the transmission into reverse
If gear clash occurs, the clutch is not releasing completely
Determine if the problem exists with a linkage adjustment, clutch or input spline damage, clutch disc damage, pilot bearing damage
If gear clash does not occur, the clutch is fully releasing and working properly
KRUMARO!!!
[Modified by Mikey, 6:40 PM 9/21/2002]
Inside the car:
Under the hood
Oil level
Driveline condition
Static Shift Test
Dynamic Shift Test
Shift into reverse
Shift into first
Note unusual noises
Clutch Spin Down
KRUMARO!!!
DLS2000Accord
06-26-2017 09:38 AM
JDMlyfestyle
21
09-24-2004 02:08 PM
