need help on air conditioning
ok im working on a friends car. all of the a/c was taken out by previous owner to put in a turbo, my friend bought all of the a/c stuff to go back in.
i put all of the a/c parts back in the car and it doesnt work.
so far i have checked all of the fuses(i think)that run the a/c, i tried jumping the connector on the reciever/dyer and it still doesnt engage. i check for voltage at the connectors for the clutch,fan,low pressure switch, and the relays and im not geting any voltage. is there another fuse or relay that im missing? i check the 1 in the fuse box under the dash and the 2 under the hood. they are good and i have power there.is there a better wiring digram other than the chilton manual? tia
Re: need help on air conditioning (Delsolburger)
well im not getting power to the low pressure switch or the relays. i thought the ecu only provided ground to opperate the a/c,fans,etc.
