Need Help..
Need Help..
I got a 93 civic coupe and i need new brakes and its Non ABS . But i have a problem, my back brakes are the dumb azz drum brakes.So i was interested in getting some brembo rotors and some hawk brake pads in the front. But what about the drum brakes? just get OEM or what u guys think?Let me know what set up you guys recommend or any suggestions.BTW cant wait to get my rear disk brakes swap! .Please help me out here fellas!thanks
Re: (RedsunEJ2)
Go to a junkyard an find an EG Civic Si or a del Sol with rear discs and see how much they are. If you can score them for pretty cheap then go for it. I want to do this, and I will also yank a gauge cluster from an Si and some del Sol seats as well.
Re: Need Help.. (RedsunEJ2)
If your swapping out the rear drum brakes to a GSR for instance then don't forget the master cylinder, reservoir and porpotioning valve from that vehicle as well. If you don't then you'll have unequal brake balance, brakes that lock easily and more effort to just slow down.
kit50si
13
11-18-2006 06:06 AM
turbotime
07-09-2004 05:21 AM
