need help
need help
Im new to the honda world, but im pretty good under the hood and im almost there should be no loose wiggling bolts and niether should the belt be loose. Im not sure how to tightn it back up if somone could help me out thanks alot the bolt is like smack dab in the middle right under the mount its a gold color and well i need to get it fixxed.
Re: need help (Jimmy the Saint)
Hard to understand your problem based on that sentence but it sounds like you're trying to tighten a belt. I usually just tighten it so it's snug and even with the other belts and try not to go too tight. If it's too loose it will squeal when you start the car so just tighten it a little each time until you have no noise.
Re: need help (VTECorona)
i know its hard to understand but i cant figure out how to explain it it. It looks like a bolt that ran through one of the pulley or a guide wheel or something popped out and now i cant get it back in. Much less get to the pully and if it makes a difference it is an LS motor
SRd240sx
10
10-27-2019 06:11 PM
moochie972
07-04-2008 11:52 PM
