need help..
It pretty much just unbolts then bolt the new one on. You will have to rebleed the clutch. The only part that may give you trouble is lining up the bolt holes once it is pushing against that lever, it just takes a little muscle.
Re: need help.. (Costa)
remove the hydrolic line,remove the 2 bolts holding it on, it will fall off, then replace with new unit, replace bolts, attach line, and bleed the clutch. its really a simple part to replace
gl
gl
Re: need help.. (egsleepercivic)
Just make sure you don't stip the nut holding the hydralic line on. It looked pretty rusty and you'll have to replace the whole line if you do stip it.
civicdelsol33
07-28-2007 08:18 PM
