Need Cluster help
Old 01-26-2009, 04:55 PM
90teg91hatch's Avatar
Default Need Cluster help
i was wondering how do you pop the needles off the 96-00 civic clusters to chang out face plates?
Old 01-26-2009, 06:52 PM
vanste's Avatar
Default Re: Need Cluster help
you dont pop off the needles, are you trying to install aftermarket ones or what are you trying to do. if your trying to install those ebay indiglow gauges or whatever you just slide the needle through the center hole and put it on top of the OEM one...
Old 01-26-2009, 06:57 PM
Noodler's Avatar
taking off the needle screws it for life.
Old 01-26-2009, 07:02 PM
Shenanigans
H22Ej1's Avatar
this is total bs...
op to take off the needle put the prongs of a fork underneath and pull upward with slight pressure the needle will pop right off.
when you go to place the needle back on you will have to recalibrate it the easiest way to do such is leave the cluster clear plastic cover off while the cluster is reinstalled. fill the gas tank to full, put the fuel needle at the full position, let the car sit cold for a day, put the temp needle in the c position. put the tach needle at 0 with the vehicle off. put the speedo needle at a known speed (have a friend drive next to you in a parking lot going slowly to know how fast you are going)
Old 01-26-2009, 07:32 PM
hondafab19's Avatar
x2... just put your new face plate on top of your factory one.
Old 01-27-2009, 03:49 AM
well right now i am working with a auto cluster so i dont screw my good one, but i will try the fork thing, anyone else have any experience with this
Old 01-27-2009, 09:17 AM
anyone have more info on this
NOFX
30
12-22-2014 04:42 PM
CA6VTEC
07-16-2008 08:21 PM
rasinhell
05-10-2005 09:17 PM
prettysweetcivic
15
12-05-2004 03:59 PM
theNewCivicGuy
10
05-02-2002 03:07 PM
Quick Reply: Need Cluster help
