need cam info
Old 10-07-2008, 10:01 AM
paintball2089's Avatar
Default need cam info
what is the biggest cam i can use in a b18b1 without having to change the computer
Old 10-07-2008, 10:05 AM
fryguy190's Avatar
Default Re: need cam info (paintball2089)
well do you want to go with aftermarket stage 2 or 3 or r u wanting to go with a stock cam from another motor...
Old 10-07-2008, 10:09 AM
Default Re: need cam info (fryguy190)
i would like to use aftermarket
Old 10-07-2008, 10:16 AM
00b20vtecoupe's Avatar
to do it correctly ide say none.
Old 10-07-2008, 10:21 AM
so if i went with a stage 2 cam what computer would i need
Old 10-07-2008, 10:24 AM
HeikDiesel's Avatar
Why are you so set on keeping your stock ECM? You need something to tune with if you start running modifications like camshafts and whatnot
Old 10-07-2008, 10:29 AM
Default Re: need cam info (HeikDiesel)
idk much about this stuff so im askin around tryin to learn about it. im re building my head because there was a bent valve. so while i have it all apart i wana replace or upgrade parts.
Old 10-07-2008, 10:32 AM
HeikDiesel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paintball2089 &raquo;</TD></TR><TR><TD CLASS="quote">idk much about this stuff so im askin around tryin to learn about it. im re building my head because there was a bent valve. so while i have it all apart i wana replace or upgrade parts.</TD></TR></TABLE>
Well if you start upgrading beyond stock your going to want something to tune air/fuel mixtures and timing with. When you start allowing more air to enter the engine (bigger cams), you need to suppliment that with more fuel and adjust timing accordingly
Old 10-07-2008, 10:36 AM
yeah but isent the computer suposed to use the sencers to adjust that
Old 10-07-2008, 10:43 AM
haha no first off if u wanna do a bigger cam ur gonna need to upgrade ur valve train(valve springs and retainers) and then do a bigger cam and to tune ur car ur going to need a type of engine management like hondata with a new ecu such as a p28.
Old 10-07-2008, 10:45 AM
Default Re: need cam info (00b20vtecoupe)
if u were running a gsr or b16 u could upgrade to better stock cams such as ctr or itr and itr valve train which u would be able to run a stock type r computer for.
Old 10-07-2008, 01:07 PM
HeikDiesel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paintball2089 &raquo;</TD></TR><TR><TD CLASS="quote">yeah but isent the computer suposed to use the sencers to adjust that</TD></TR></TABLE>
Spell check is your friend.
Stock ECU's can only vary air fuel mixtures based off the oxygen sensor which is a narrow band sensor that only reads on a 1 volt scale. Wideband sensors which most tuners use have a 5 volt scale giving the tuner a lot better idea of what adjustments need to be made. Also your stock computer has no idea that you have aftermarket cams in at wide open throttle. The map sensor will read the same but the profile of the cams will allow more of that air to enter the engine which also needs adjustment. The list goes on and on, but since you are a trial user you have maxed out your posts for today. So ask some more questions tomorrow and I'm sure people will help you out
Old 10-08-2008, 11:33 AM
ok thanks but im running a b18b1
blurry454
11-18-2009 11:55 AM
nyghtryder
Honda Civic (2001 - 2005)
10-27-2007 12:28 PM
gsrturbo-ek
07-20-2007 03:31 AM
white ej2
10-06-2006 08:48 PM
.ShawnD.
03-28-2004 05:28 AM
Quick Reply: need cam info
