Need a cam... Did they make one for a D series that is turbo'd???
Hi I am currently looking for a cam specifically made for a D series (hopefully made just for a D16Z6 ) that is turbo'd. I don't want that Zex crap. Does anyone know where I can get one?
Re: Need a cam... Did they make one for a D series that is turbo'd??? (MyWhiteCivic)
Re: Need a cam... Did they make one for a D series that is turbo'd??? (Spade)
gude makes a turbo cam that puts down 20hp to the wheels but it costs $511.00.
Re: Need a cam... Did they make one for a D series that is turbo'd??? (UNDER PRESSURE)
Wow, I can't afford 500 bucks for only one cam.
What do you mean by just a core?
[Modified by MyWhiteCivic, 5:25 PM 11/26/2002]
Re: Need a cam... Did they make one for a D series that is turbo'd??? (Nextekhatch)
zex cams, made by comp cam. http://www.zex.com
Crowers also have a odd tendency to break in half w/o their valvetrain.
Crower DOHC cams had a "bad batch" the SOHC's have never broken.
EDIT: What a mean by core is that they have blank SOHC cams made and then grind them down to the specific durations and lifts.
They do not fuse new material back onto the cam and then grind to spec. Like a "regrind"
[Modified by Spade, 3:00 PM 11/26/2002]
Re: Need a cam... Did they make one for a D series that is turbo'd??? (splitime)
Crower's new D16 SOHC VTEC cores are now available to the general public. No longer will you be subjected to bad regrinds that not only do not perform as advertised, but will also wear out over time...some shorter than others. As usual, Crower offers several different profiles to choose from, including a turbo grind that features short duration, low overlap and high lift for optimum performance. All motor and full race profiles are also available.
Stage 2 - Designed specifically for turbo charged and supercharger applications. Features short duration and high lift. Requires springs and retainer kit
Do you have to use their springs and retainers or can I get other brands that will still work with that cam?
Other brands will work.
The reason you have to use new springs is the fact that the lift is so high that the stock springs will not pull the valve closed in time and the piston will contact. I.E. Stronger springs.
Gotcha. Thanks for the information. I'm going with the Crower stage 2, thanks for all of your help Spade!!!
Not to be a pain in the *** but do you know anywhere that sells Crower cams for cheaper than list price?
Thanks again!
Thanks again!
Thanks again!
Thanks again!
hey spade, question for ya bout the cams...im swappin in the Z6 head onto the rest of my Y7 engine, and i wanna get a new cam too, would a cam "for" the Z6 or Y8 engine work in my car?
cueballsi
10-06-2004 09:57 AM
