Need Answer ASAP please... TEINS from GSR.. will they fit 1999 Coupe?
I"m buying some Tein SS coilovers from a guy locally...
They are from his GSR... will they fit my 99 civic coupe ? I need an answer ASAP please... Thanks and I searched... https://honda-tech.com/forums/images/smilies/emthup.gif also... any modifications or anything? |
help !
Re: (99SlammedCivic)
nope...maybe only the fronts..
not backs..forsure... they'll only fit 92-95 civics. |
Re: Need Answer ASAP please... TEINS from GSR.. will they fit 1999 Coupe? (99SlammedCivic)
the fronts will be no problem...
the rears, the strut fork is too wide....you'll need to use washers to make up the difference..... the EK LCA bushings is slim while the EG/DC ones are pretty wide......so washers do the trick.... |
so is that all I need to make them work on the rears?
Washer trick? 2 on each side ? Thanks for the info & keep it comming ! |
why dont you call tien or check their website?
Re: (eg6si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6si »</TD></TR><TR><TD CLASS="quote">why dont you call tien or check their website?</TD></TR></TABLE>
u mean TEIN ? https://honda-tech.com/forums/images...s/emsmilep.gif I just wanted to see if it can be possible according to my fellow ht peeps ! Thanks |
just about.......4 on each side of the car.......2 on each side of the bushing.....make sure they fit snug on the bolt though...and the highest grade you can find...
any more input ??
Thanks |
Re: (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloCivicHMM »</TD></TR><TR><TD CLASS="quote">the fronts will be no problem...
the rears, the strut fork is too wide....you'll need to use washers to make up the difference..... the EK LCA bushings is slim while the EG/DC ones are pretty wide......so washers do the trick....</TD></TR></TABLE> <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 »</TD></TR><TR><TD CLASS="quote">washers= https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> Sounds good 2me... if u guys say it works, I'll take ur word for it ! https://honda-tech.com/forums/images/smilies/emthup.gif |
