Need Advice from seasoned honda owners
I am looking into rebuilding my d16y8 which currently sits at approx 198,000 miles , what rebuild kits are out there that are reliable and cheap
- thank you
- thank you
I never narc'd on nobody!
Re: Need Advice from seasoned honda owners
That kind of information can easily be found in the stickies. I also summed it up neatly for you in my first response here - OEM, or OEM equivalent. Gates belts, Yamada water pump, OEM or Cometic gasket kits, Nippon rings, OEM bearings. As long as your piston ring lands aren't damaged, you don't need to replace them. As long as your rods aren't discolored or marred, you don't need to replace them. As long as your crank isn't marred, you don't need to replace it. As long as your sleeves aren't marred, you just need a basic hone to clean them up.
highroller54
Honda CR-V & Element
12-01-2013 08:59 AM
seanhatch95
04-18-2012 08:16 PM
the.hamburglar
01-11-2006 08:03 PM
