need advice on ls/vtec?? what should i do??
i am going to pick up another 4 door civic ex today in ny. it has an ls/vtec in it but the guy says he has a civic vx ecu on the car right now. he says the motor runs nice and quiet and i can compression test it and drive the car of course if i want. my only concerns are the ecu and how should i expect the car to run and drive?? i just dont wanna get fucked. i have an obd2 ecu for a gsr, if i plug that in will the car run?? will it run better than the vx ecu?? i know it will throw codes but i just need to know the car/motor/wiring/tranny are ok.. so please gimme some input on what to look for.. thanks
Re: need advice on ls/vtec?? what should i do?? (mycvc8u2)
dont expect the car to run all that great nor to be fast as it should be..a non vtec ECU in a vtec motor plus it wont be getting enough fuel and so on..
adaM
adaM
Re: need advice on ls/vtec?? what should i do?? (STEALTHMODECOUPE)
so as long as the motor has good compression and all the vtec wiring is there it should be fine except for the ecu?? as much feedback as possible!! thanks
Re: need advice on ls/vtec?? what should i do?? (exospeedAMcrx)
vx Ecu is kinda considered a VTEC ECU. you can reporgram that VX ECU to a DOHC VTEC program.
adaM
would the car engage into some kind of vtec at all??
adaM
well i kinda thought that the vx was vtec-e?? the cheap vtec-really cheap-just like the 96+hx civics....
[Modified by mycvc8u2, 10:16 AM 1/14/2003]
