need advice on h22 civic buy
Hi am considering buying a Civic hatch with h22 swap and would like some advice. I do not know much about modified Civics and i am not looking to step in a pile of crap, ya know.. i will be investing all the money i have for a car into this and would appreciate any advice that you guys can give me. take a look at the ad:
1994 Civic Hatchback Si Blue
Very low miles on the body, 20k on 220HP JDM H22 motor!
Inside:
Car has GSR seats in mint condition no rips at all
Kenwood CD player
Car is wired for subs
Momo Foot pedels
Viper Alam System
Outside:
100% RUST FREE!!!
GSR disc brakes all around
KYB 4 way adjustable shocks they have race setting and everyday driving.
Skunk2 lower springs
Type R side skirts
Car has been paint ALL SI Blue (motor bay, door jams) PAINT IS MINT!
Window Tint
OEM rear front Bumpers
SI Red&White Tail lights
Fiberglass Cowl hood. With forced intake duct that works.
Steelies for rims nothing special but there light!
Duckbill with LED lights on it
Motor:
Hasport Rear and Front motor mounts
AEM fuel Rail
AEM Fuel Pressure Regulator
B&M Fuel Pressure Gauge
GSR ECU (car redlines at 8,200RMP!!!)
Duralast Power Newer Battery
Walbro 255 fuel Pump
No A/c or Powersteering
Rear and front strut Bars
Stage 4 clutch not sure what brand
Steal mesh fuel lines
Fluidyne Chorme Radiator
Spectre Turbo Intake
Clisco Fuel Resovore
Greddy Full exhaust
Im sure the car has over 250 horsepower and it an easy 12 1/4 mile car. THIS CAR RUNS VERY VERY GOOD, MOTOR IS MINT! BODY IS MINT TOO!
Needs new axle on passager side, has a gsr one but its two short so it grinds when it drives not loud but need a h22 inner shaft looking at about 30-50 bucks. Also needs a new drivers with was broken into nothing was stolen. Other then that car is great, you may notice airbag not in drivers side because it had in aftermarket steering wheel and the air bag was not put back in when old steering wheel was placed back on.
"Needs new axle on passager side, has a gsr one but its two short so it grinds when it drives not loud but need a h22 inner shaft looking at about 30-50 bucks" - are these expensive repairs to have done at a shop, and are the parts hard to find? would driving the car like this be a bad idea?
the car is sharp looking. it is advertised as the "h22 220 hp" motor which would be the type s, but the picture looks like a h22a motor. is this right? i attached the pictures of the car. lastly what kind of 1/4 miles times would be average on a setup like this given the driver knows the car well. when the ad says "could easily run 12's" would that be an accurate number? is the 250hp claim also accurate?
any help is greatly appreciated.
Inside:
Kenwood CD player
Momo Foot pedels
Viper Alam System
Outside:
100% RUST FREE!!!
Type R side skirts
Window Tint
Motor:
AEM fuel Rail
Greddy Full exhaust
Re: need advice on h22 civic buy
The 250 HP claim is most likely false. The ad looks fine and so does the car. But pictures do no justice. You will need to drive it to find out more problems. I would probably get the correct ECU for it. Hopefully he has the airbag as well. Airbags are not cheap. Axles [brand new ones] can run you as much as $75-90 a side.
When you take it for a test drive, be sure to check for common things:
-A shaky steering wheel or a jumpy brake pedal while braking means you have brake problems.
-Does the car drive straight? Get on the highway and go speedlimit. Take your hands off the steering wheel but close by. mash on the brakes for a second [ensuring no unsuspecting person is behind you] and see if the car pulls left or right. If it does, you have alignment issues.
-Does the steering feel floaty? More alignment issues.
-Check SMALL stuff to to keep you happy. EX/Si cars check the Cruise control, power windows and locks, sun roof, etc.
-Make sure your heater blows hot and your A/C blows cold. Again, small things to keep you happy.
-Ask how regularly it was serviced. When was the last time it had new plugs, wires, oil, etc. Ask the type of oil as well.
That is pretty much all I can think of right now. Maybe some others can chime in on things you should look for =]
Good luck with your first buy!
Drive it first make sure you like it. Transmission grinds are common with h-series trans. The car is no where near 12's, and is no where near 250hp.
Edit: And its not worth 5500. He'd be lucky to get more than 4000 for it.
It is worth whatever the person buying will pay for it what are comoon 1/4 mile numbers for a hatch h22 with interior still in tact? i know that question annoys people but i am just looking for what someone else may have run. on street tires..
A stock jdm h22 dynos at around 176 wheel horsepower with 153 foot pounds of torque. With the bolt on's like the intake and exhaust you might be up another 15 hp. But it most likely doesnt make 250. The stock specs for crank horsepower are 220hp with 203tq. So you wont actually be putting those numbers on the pavement. Another thing to consider is that 100% rust free EG hatches are very hard to find. Fresh paint may have covered it up, but that doesnt mean its gone and wont come back. So when you check it out. Feel inside the fenders to see if there is any rust and see if there was any bondo or body work done to hide the rust. The thing that would concern me the most would be the axle. The owner put on an axle that doesnt fit properly and is obviously damaging the transmission. That might indicate the kind of care he took for the vehicle. Matt's advise is the best. Drive it and look at it. Pay attention to any noises or shakes.
Well the person paying 5500 for it would be getting the short end of the deal. Common 1/4 mile times for h22 swaps on street tires are high 13's.
imo 5500 if bumpers r matching at least but thats still high to me. how it is currently 4 -4500 is being realistic since u would have to paint and do axel work off the bat.
why would you want to buy a civic with a swap? in my opinion, most people do a swap for more power. i mean, you wouldn't swap in an h22 just so you could say you have one, you would do it for racing. that engine is probably beat up pretty good if i had to guess. but then again i may be wrong.
an h2b eg is not worth 5500 in the form it sits. offer 4500 if he has papers on that swap, no more than 4 without papers. if it is a 220 hp spec h22 then expect around 185 wheel horsepower which is not 12 secondable....
Ok thanks for the advice!
Yea the selling price is just high to negotiate i am sure..
where does it say it is an h2b? an h2b eg in this shape would be worth about $4500 imo cuz the ****in adapter kit alone is almost, if not over $1000. OP, this car imo is probably worth about $3500 because the paint doesnt match and that swap doesnt look the best. im guessing the guy who did the swap also left some of the mounts off...which equals trouble. if it had good wheels and tires, a good paint job, better swap (if the job was done better...imo only 2 things beat an h22 hatch--h2b and a k20) then yeah it would be worth it. its not our car but we are trying to keep you from buying someone elses problem...
Yeah, there is no rust on the car at all, and the swap was done right. It runs like 13 all day long when I had it. yeah the half shafts went out sometimes, but I was useing accord halfs in it. Other than that the car is solid. And when I had it I babyed it, I only ran it one day.
man honestly i wouldnt go for it the h22a civic swap is a waste of money in my opinion if all your gettin is high 13s...i get that in my b16a hatch with jus a stage three clutch and a chipped ecu...and u kan find civics with a b16 or b18 for way cheaper then 5500 and his the same track times...and i agree with them check for rust covered up by paint
