nasty grinding noise when letting off the throttle on my 97 ex coupe
i have a bone stock coupe and its making a grinding sound when im in gear and let off the gas, it is pretty loud and two shops told me it was my tranny, so i swapped it out the other day and put a new throw out bearing and it STILL makes this annoying noise. i have replaced both axles and the tranny so far and my problem is still there. anyone ever had this happen to them? and how can i fix it? thanks guys
I'm not Rick!
Re: nasty grinding noise when letting off the throttle on my 97 ex coupe
wheel bearings? if its these. they would have made the wheel falll off by now though
I'm not Rick!
IF you do take it off agian...i know it sux but. if you do have to i would check the clutch if you find that that bearing is perfectly fine.
i just got done fixing my car (had to take the tranny off 4x)..nightmare...gravel. no ground clearance, in the rain...ugghh. well good luck.
KILLA CAM!! its ur muffler bearings hahah.. jk.. wad up ***** ****a! its B-rad.. i didnt know u where rockin honda-tech..
its ur tranny trust me.. my 97 coupe did the same thing.. its actually the input shaft bearing inside of ur tranny its VERY commin on the 96-00 d series trannys...
Whats up Brad!! Yea i been on here for a minuete now, ya i thought it was the tranny but i swapped in a 95 dx tranny and it still makes grinding noises when i let off the gas while driving, i thought i had a clutch but i dont so its still effed up, wah wah wah
CrisEK
Suspension & Brakes
10-02-2010 05:54 PM
